hey guys im looking at the hpop cover i cant find anything on removal or installation of hpop any info would be great. just trying to find out some tips and tricks anything to make my life easier
thanks
thanks
Because of this I was soooo nervous when i did my HPOP STC fitting. I ended up not dropping anything, but was shaking the whole time lol! But it worked, almost. I apparently forgot to tighten the feed tube down and an o-ring. so it just died on me shortly after. All good now tho.I second the recommendation to be careful with the bolts. If you drop one you're in for a lot of work and time if you can't fish it out from the top. I don't know if you can experience a sicker feeling when working on this motor. It really happens a lot and often leads to removing the transmission and rear engine cover as cranking the motor with a bolt in the gears would be sure destruction.
