here are the symptoms that i am having:
1. most of the time when my engine is off for only a few minutes before restarting, the engine speed fluctuates, then levels off and idles normal.
2. this one only happens when i am seriously on the throttle, i am getting on the freeway or passing someone on the freeway, i get the check engine light and slowly lose power. i pull over and turn off my engine and give a few seconds before restarting. the check engine light is no longer on and i have normal power levels.
unfortunately this appears to be a "soft code". several mechanics have told me that in order to figure out what the computer code is, i need to catch in the act of losing power. unfortunately, i am no where near a shop when this happens and i don't have a scanner to use.
