Ok, so I have been chasing a "ghost" for long time now. About 2 years.
It almost seemed intermittent at times. Now, I can turn it on like a switch.
These were some other threads with similar issues, or my threads:
http://www.powerstroke.org/forum/6-0-trannie-problems/261950-4th-5th-converter-lock-bucking-slipping.html
http://www.powerstroke.org/forum/6-0-motor-problems/263506-bucking-hesitation-missing.html
http://www.powerstroke.org/forum/6-0-motor-problems/213427-6-0-missing-during-acceleration.html
http://www.powerstroke.org/forum/general-6-0l-discussion/260488-6-0l-bucking-losing-hpop-5th-tcl.html
Truck was bucking on the highway, in 5th, with TC locked.
Passes all injector tests, hot or cold. Never throws a code.
Here are my symptoms & facts:
-only on the highway
-noticeable on flat ground, but more so on a hill/incline
-only happens with slight throttle input (20-50% throttle, roughly)
-only after trans is up to 140* or higher
-only in 4th with lockup, and 5th with lockup (via Edge Insight)
-truck lunges/bucks/shakes with slight throttle application
-smash the throttle and it screams, no issues
-if you hold the throttle just to maintain speed (or decrease speed as you inclince), it wont do it
-much more noticeable with my boat in tow, higher load on engine/trans (boat, trailer, gear weighs about 5k)
-no codes
-all engine parameters stay solid during the bucking
-FICM 50V+
-RPM does not flicker
-ICP voltage solid
-HPOP psi steady
-Fuel pressure never drops below 59psi, usually steady at 61-63*
-ECT never above 195*, 205* max towing
-EOT never above 195*, 202-203* max towing
-Both near 189* while around town
Recent maintenance or upgrades since the issue started-
-Trans fluid drained around 75k (91k on clock now), new pan gasket, filter, and TP filter, Mercon SP, fluid level dead nuts in the middle the "H" when around 160*
-8 new injectors
-new frame mounted fuel pump
-BPD 53V FICM, 6phase unit
-BPD tested Logic board FICM
-IDP FICM tuner
-FICM wiring harness
-Shell T5 Rotella
-Shell Rotella ELC
-Fuel filters every 5k miles
-Front & Rear diff fluid changes
-Transfer case fluid change
-New HG's (Black Onyx failure)
-ARP's
-New OEM Ford turbo (not a rebuilt)
-IDP long Y-pipe (EGR delete pipe)
-Riffraff Diesel intercooler boots
So, the newest problem surfaced today.
I always keep an eye on my Edge while driving, and today I noticed my HPOP psi was not building as high as usual.
Went for a quick blast up a side street, she wouldnt build more than 1600psi.
I remember seeing 3000+ on a WOT blast.
It seems to be sticking around 1400-1600 under heavy throttle.
My only question is, is it possible the IPR is stuck, not allowing the pressure out of the pump?
Either way, I am at 93k miles, I think I am replacing the HPOP and IPR now any ways.
-no codes
-FICM 50V+
-ICP voltage solid
-HPOP psi steady
-8 new injectors
-IDP FICM tuner
-Shell T5 Rotella
-Shell Rotella ELC
-ARP's
