Hi Guys,
As soon as my truck is off warranty (should be around 130,000 km) I will be pulling the cab off myself to remove the entire EGR system, DPF system, add an airdog and mini max tuner (stock power with EGR and DPF delete).
My question is, while I have the cab off, I can buy a brand new HPFP for under $1100, that seems like cheap insurance to me. I am viewing the HPFP as like a timing belt on a small car, not worth the risk of waiting for it to fail.
When do you guys think would be a good time to change out the HPFP and or the injectors on this engine?
Do you believe the injectors pose a risk to let them fail before replacement? i.e. hydraulic lock, scorching etc.?
Thanks for your input!
