1 - 5 of 5 Posts
I need help asap! any body have any experiance on how to tell if its just my orings or is my inj fubar all of the inj on driver side are dry except #2 its puking out oil like a water fall right by the retaining bolt & bracket 99 7.3L:dunno:
sounds like a bad o-ring...take her out and check the o-ring since your in there.does it smoke??? what color if so??
ohh yea! when you get that inj out,take a flashlight and inspect the inj cup very closely, for cracks and what not
ok will do it does not smoke any at all this mtr only has 22k on it reman l block frrom ford i bought it with 18k on the new mtr thy did test all the inj and it looks like they only repaced the defective ones the have AB on them
yea the ab code i beleive came on the 99 and up,those are split shot injectors.are any of the aa ao on top??? if so those are single shot and came with the obs trucks,98 and down,were are you located??? i gotta scanner and all,that wont tell you about the o-rings but it will take alotta guess work outta the equation...pull #2 and check out the o-rings.install and see were your at then...are you losing power???
1 - 5 of 5 Posts
