1 - 20 of 21 Posts
My computer i was useing to install tunes into my x3 crashed. i was wanting to no if its possible to download a new sct updater to my new comp? if so how can i do it? i still have all my tunes saved on my email. thanks sam
You jus need to go to the SCT site and download it again.
thanks it wont be screwin up my firmwall or anything? since i changed computers and its a newer software?
You shouldnt have any problems, I didnt anyway and I think SCT is a pretty safe thing.
No, the firmware on your SCT will not be affected by the uploader program unless you were to try to update your firmware.
I run one on my laptop and one on my home pc, the one on my laptop came with my xcal2 and the other I downloaded.....they both work fine with no problems and they are differen versions.
What you will do is go to SCT Automotive Performance Products then select Tech Support. After that you will go to device updates and downloads, in there you will select your device and then select device update software then search. The software will pop up and install that, load your drivers and you will be all set to load your tunes again.
thanks for all the Info guys!
Discussion Starter #11
one more question do i need to plug it in and update my firmware?
Discussion Starter #13
iam not sure but thats the directions it showed? i didnt no if you only had to do that when u first install the device or everytime you change computers.
What device do you have as well? What you will do is plug the device in and go to device info and that will show you what Firmware is on that unit.
Discussion Starter #15
i got the x3 i bought it in early 08 so iam sure it dont have the lastest firmware.
Discussion Starter #17
is it ok to download that new firmware onto my tuner?
Discussion Starter #19
serial number X30220080230c. the fw Rev is 1.1.131
What I recommend is return the vehicle back to stock and update the device to the latest Firmware and then Format the device, load the Firmware, format and then load the tune revision.
1 - 20 of 21 Posts
