some thief tried breaking into my truck and smashed the lock, i picked one up from ford but to set it up you need the key code where do you find it, i looked in my owners manual the only thing i have is the code for the keyless entry but that's not it.
interesting link but i'm after the actual master key code as if i was going to get a new key cut, not the keyless entry code.
duct tape & zip ties
Go to a lock shop. They will be able to code the new ignition switch.
Now if your needing the door lock coded they can do that too. Usually charge around 15-25 dollars to do this. Only takes them about 10 minutes to do it.
