how do you do a fuel pressure test? im going to check it but i dont know how lol:hehe:
you can rig up a gauge to the drain valve outlet on the back side of the bowl. you will need to use a hose clamp but it is the "easiest" way to rig up a gauge.
But that will only test pressure to the outside of the filter. The best way to do it is to screw a gauge into the test port on each head. One is on the front of the passenger side head, the other is on the rear of the drivers side head under the turbo.
