1 - 18 of 18 Posts
well i think ive figured i have a frankenstein front end. I have a 1997 truck with what looks like a 1992-1994 axle. My knuckles have a slide pin calipers.
my question is can i just get 1997 knuckles bolt them to my axle and get the new bolt on calipers and be on my way?
Yes you can, I just went and did a whole axle swap twice for that reason tho
Found another axle easier than finding knuckles only
is there anything else i need to replace when changing these old slide pin knuckles and calipers to the bolt on caliper and knuckle?
will the rotor be the same? who has done this?
Found on craigslist, both, but youwill needknuckle, cakiper, and the rotors, theyare smaller. On the older axles
hey guys...ive searched everywhere google will take me and i cant find 1997 knuckles...found a couple axels on craigslist that are already sold
can someone point me in another direction to find some knuckles???
Anything from 95-97 f350 only, try ebay? Would a dodge d60 knuckle work?
I have heard of Dodge guys running older Ford knuckles to eliminate the unit bearings. You would have to run Dodge spindles and hubs as the bolt pattern is different and I think brakes too.
My stupid slide pins don't quite stay put for some reason. Let me know how the conversion goes, I may be interested in doing it myself.
Dodge has same bolt pattern except. 2011 max tow package
On the spindles?
Discussion Starter #12
so your saying if i found a a dodge knuckle, caliper and rotor setup everything else would bolt up correctly??
but to answer the first question, yes ive even tried ebay. i actually found a pair of older 1992-1994 knuckles but they have slide pins and i really want to upgrade to the bolt on calipers.
is there any aftermarket company that makes the knuckles? ive seen a few but only for king pins.
No idea but dodge is more plentiful in yards lol
But someone said before about unit bearings is only thing so I'm not sure, eithet way axle came from dana
I don't have much info on the Dodge knuckle other than hearing about some people upgrading to Ford knuckles on their Dodge. You would possibly need the stub shafts... heck just get the whole Dodge axle and swap everything from the knuckle outwards. Worst case you would need to reuse the C's from the Dodge axle and get custom length shafts. You would probably find more info on pirate4x4, IIRC that's where I read something about the knuckles.
Discussion Starter #17
well my father in law is going to check in the middle of the state where he lives (florida) there are a lot of old powerstrokes up there so maybe ill be able to get an axel soon. ill keep you guys who are interested updated on this.
Discussion Starter #18
well its been a while and a lot of searching with no luck on finding some bolt on knuckles.
So im fully open to just replacing my 92-94 slide pin caliper knuckle.
Does anyone know of a passenger side slide pin caliper knuckle that is being sold!!! I havent driven my truck in almost 2 months, im getting desperate.
1 - 18 of 18 Posts
