i really need to know how to clean this egr before it gets worse any help would be really great thanks
i just went through this yesterday, it is frusterating. take out the 2 8mm bolts holding it in. then try tapping onthe flanges to get it to turn a bit, this helps to loosen it up. once you get it to turn, use a long common screwdriver that will fit under the intake elbow, and get it under the valve itself, then give a little pressure and pop it out. good luck. it took my 2 hours all together to get it out and clean it. most of that time was getting it out. a puller would be alot easier.
thanks what should i clean it with
carb cleaner works real good. get a soft brush like an old tooth brush or even a brass brush so you dont damage it.
