1 - 14 of 14 Posts
Reliable for the vast majority of owners. Of course, you're in a public forum so you're likely to see more doom and gloom. The main areas for motor failure are broken valves and turbos from what I have gathered in perusing various sites.
Just leaf through the forums and you'll get an idea of what people like and dislike.
Consumer Reports rated the 2011 6.7 SD the highest vs Dodge and GMC. I like to watch the forums b/c it gives me an idea of what problems do exist, and there is also a lot of great information, pictures, and helpful information and upgrade info.
I think this truck will prove very reliable. For all the people that say they are scared of them, just go look at any other forum. I jumped on the Duramax forum this week and you see all sorts of posts about issues. Do I think that's the norm? Nope. Same goes for Ram and ATV forums. People often hit forums for problem resolutions, so I think they are skewed. And, it's easy for 2 people with issues to have a ton of posts and lots of activity.
I have 7100 miles on mine and just love it. I came from a line of Toyotas which are very reliable. When I wanted diesel, I wanted IMO the best...and I ended up with the SD.
I am a 2012 6.7 L owner, and I did comb through the Duramax and Dodge too, and I do not see that many major issues with them, but their motors have been out for years. This new motor seems to have a few valve issues, maybe some turbo issues, and black coolant issues. Ford is doing good with this motor so far from what I have read.
I also love my truck and want to look out for potential problems.
I bought a 2012 ram cummins last month and was so unhappy with it I traded it in and bought my 2012 f250 crew short bed 4x4 i took a loss but it was so worth it to be happy. its a night and day difference more power, much smoother trans, way better ride and wayyyyy better fuel econ.
The usual issues are, turbo failures, dropping valves and weak rods. I've seen all three fail in stock and modified applications so it has nothing to do with changes you make performance wise or not, the issue is already there from the moment it left the assembly line. Now I will say it seems to be hit or miss, not sure why that is though. But if you own one of these trucks they have a very sensitive fuel system so do your self a favor and drain the water separator once a month like clock work if you like not having issues there. Water in fuel is a big concern on these and the new Duramaxes, the CP4 is highly sensitive to even trace amounts.
119,000 miles... tuned for 23,000.... emissions deleted primarily for engine longevity. Very comfortable regarding relability... This truck is a job 1, the tranny solenoid pack was replaced under warranty, I believe this is comparable to the 7.3. I had 340,000 on it and this truck reminds me of it in the fact that it just works, runs, no issues...
Rich how is the truck after deletes, MPG, Driveability smoothness,oil stay cleaner, power Ect?
At what mileage was the trans warrantied?
curious about this myself??
Oil looks like new, after 7,000 miles the synthetic is dark, compared to being black right after oil change stock.
Driveability after deletes no different, more power... I run HOT on the H&S, with defuel levels set at 1200 egts, which is low, but safe for me.
Transmission pack warrantied around 23,000. The tranny about every 1600-2000 miles would 'miss' a shift, free wheel then dump the power into gear!! Like dumping the clutch resulting in tires barking. Ford changed out tranny solenoid pack, no other issues.
Mileage...My tires are not the greatest for mileage, BF Goodrich AT...and it
depends on my driving, I have driven around town, babied it and have gotten 19-21 over 3-4 hours driving. I get 17-19 consistently on 65-74 mph on highway. I pull a 16k fifth wheel often and at 60-65 get 11-12+, at 70 and greater it drops to 9.5-10.5.
I have had five diesel trucks before the powerstroke , they all had issues at first especially when a new engine comes out,2001 duramax had injectors replace several times, the 2004 duramax also had injectors problems, 2006 cummins had transmission replace, 2012 powerstroke is currently at the shop getting def injector replaced, 2007 duramax never saw the shop totaled it at 165k miles tuned with efi-live since it had 4 miles on it, every manufacture will have small problems, I bought the 2012 f250 because of its safety ratings
I forgot to mention out of all three I love my ford best!, the worse one was the dodge, it rattle and I constantly work on it,i bought because of the engine but the truck fell apart around it. My ford turns heads and it's solid.
I tried two Dodges, 06 and 08 Megas. Just like Hunter69 said, engines great the rest had issues. I also tried two Duramax's with the same results. So far the Superduty Rocks!
I have purchased 5 Dodge Cummins trucks and 2 Ford Powerstroke trucks. The '97 dodges were awesome. The '03 Dodge I still work very hard and it has always been great. The '05 and '06 Dodges were....disappointing. However, the 2000 Ford Excursion has and still is perfect. I also love my '12 F350 Dually. I will keep the Fords for a very long time.
1 - 14 of 14 Posts
