1 - 8 of 8 Posts
Let's go B's!!!!
Get in touch with BLK PWERSTROKE. He is selling a 7.3 motor and a tranny. You could compare a rebuild with the price of his... Just a thought...
ive beenn doing stock engine overhauls for around 2500 to 2800 dollars , thats rings bearings , oil pump if needed , all gaskets and seals ,injectors o-rings , and valve job
trans ive been getting done just back to stock for around 1500, with converter
that is unless someone wants better than stock parts , then it goes up from there
is that including labor and pulling the motor? I would have thought it was much more.. shoot if thats it Ill pull mine and put forged rods in it soon!
yeah , 25 hours for overhaul at 60 dollars an hour , leaves 1000.00 + dollars to buy parts , parts arent that expensive sometimes , depends on what it needs, i can do it in 12-15 hours so , as long as i can make good time , than i cant lose
Hey Scuffy, when you moving to texas?!?! Its nice here! you know you want to move here! there are lots of PSDs on the road.
25 hours to pull the motor rebuild it and install, you must do this alot! :hehe:
i can do it in less than that , i would love to move to texas , im not kiddn , i want to make a change bad
you must do this alot! , i cant even explain the volmue of psd work i have done and still do , it would blow your mind , thats why im tired all the time:hehe:
1 - 8 of 8 Posts
