Modding the IDM, how much more hp will it give you? and were can i get the resistor?
From what I have heard it won't reduce your MPG. By upping the voltage, you make the poppet valve open faster. I don't know or think it will reduce the life of the injector.what will this do to my MPG's?? will it hurt it?
Thanks strokin_early_99 for the great sites
beyond that, it will give you better throttle responce, and maybe quicker acceleration.
I don't believe HP increase, cause your fuel is atomized by the HPOP, not the poppet valve. All it does is allow the HPO to enter the injector and push on the intensifier piston.
And all this is what I got from Mike CLeary's class. And that is my :twocents:
And I would rather have a chip, then do this mod.
You are correct that is helps open the popit valve quicker. This is where you get your performance gains. The longer the popit valve is open the more oil it will let pass and the more fuel you will get. However you could also just ask for a slight bit more pulse width with a chip to get the same effect.From what I have heard it won't reduce your MPG. By upping the voltage, you make the poppet valve open faster. I don't know or think it will reduce the life of the injector.
