1 - 16 of 16 Posts
Just what the title says... I know about the external filter in front of the trans pan on my job 1 08, is there also an in pan filter? Thanks guys
Administrator
no it's a screen and does non need replacement
if u decide to clean it or drop your pan for any reason the gasket is reusable
Administrator
I actually just bough the in pan real filter like the later trucks use and bought a derale pan that can accommodate all years and filter types thanks to a removable bracket
the reason I swapped is because the in pan filter filters all the fluid all the time unlike the frame mount
So you changed your actual pan and that allowed you to use a late 08+ in pan filter?
Don't you worry about it
If you have an job one there is an internal filter and an external filter and when the dealership serviced mine they changed both.
Yep. I have a job1 and changed both internal & external filters. I guess some people don't change the internal as frequently as the external. But I have changed both every 50,000 miles.
Mine is the job 1 with external filter I don't feel the need to swap to the later style pan. Stay on top of fluid changes and that external filter will do just fine I know of a few job1 truck original tranny with well over 150k miles
Administrator
I wonder Why Ford doesn't even recommend that the internal pan filter 0n a job 1 be changed .. is a screen to catch large debris .. u can clean it
I am pretty sure Ford thought going back to a real filter in the pan on later trucks was a good idea or they wouldn't have spent the money to redesign the system
I know I feel better having all the fluid filtered all the time vs the bypass and reduced filtering of the remote filter makes Me feel better
There is a filter in the pan, not just a screen.
Ford told me to change both
Administrator
they were wrong I wonder if they actually changed it at all or just charged you ??
look at your manual Ford specifically states the procedure as external filter
even in the 4th printing it notes only internal filter change for those not equipped with external
I changed mine myself. Internal & external.
They changed both of mine, I watched them do it and it sure looked like a filter that should be changed.
I understand what zmann is saying I changed both of mine myself multiple times on fords recommendation and the internal is more of a screen type filter than a paper filter but it should definitely be changed. Mine had all kinds of large particles and stuff in it.
1 - 16 of 16 Posts
