1 - 11 of 11 Posts
Hey, it seems that all I do is ask questions here so I'm sorry for that, but I want to make sure Im going with good parts within my budget.
Ok here's what I'm looking at, I can get an 8" Rough Country 4Link for my 08 F250 for not a bad price.. But how well of quality and ride is the system? Compared to say a BDS? Im for sure going to upgrade the shocks at least to Bilsteins.. Im going to be running 38's with 20x12 rims, will the tires look small on an 8" lift? Thanks for all the help once again guys. Hopefully I'll finally make up my mind before I leave Iraq.. haha
Rough Country is know for riding rough, hence the name.
I've heard guys on here talking about their lifts sagging after a year or 2, and the materials are poor quality.
Just my .02.
Then again, there are probably others that have had better luck. I personally went with Pro Comp.
However, like many, many people on here will tell you - "You get what you pay for."
Retired Soldier!
I have pro comp on mine and am happy with it too.
Vendor
If your open to other companies kits, I have a 4 link that uses the Icon dual rate springs and will ride much nicer than most other kits out there. I can give you full details if your interested.
Hey Trevor, from everything I've seen the parts ya'll do are really nice! If I can fit everything in my budget them Id be more than glad to go that way.. Let me know. I'll also PM you too. Thanks!
Vendor
Cool, I didnt want to jump into a thread about anothe companies parts and come off as my parts being the only quality product out there. There are plenty of great kits out there, never any hard feelings when people go a route different than ours!
A complete 8" lift (no shocks) would run $1600. It would include everything you would need except shocks
Standard features:
7" Dual rate springs
1" spring relocator
HD drop track bar bracket
Drop pitman arm
Extended SS front brake lines
Fully adjustable front 4-link kit
Rear fabricated blocks
Ubolts
Optional parts would be:
HD solid mount adjustable track bar- +$550
HD single peice draglink- +$350
Adjustable center carrier bearing drop- +$150
Rear traction block upgrade- +$600
I do believe I have a new kit.. lol.. but questions.. would the optional parts be necessary? Can you fill me in on what those parts would do, or benefit me to have them.. I'm trying to gain as much knowledge on the lift kits and parts, I'm more used to smaller cars haha.. Let me know!
Vendor
No, the optional parts arent necessarily needed. The traction block/bar setup will prevent axle wrap which is common with the '08+ trucks. They typically put down more power than previous years and have a softer longer spring that is more prown to wrapping. The solid mount adjustable track bar will allow you to center your axle at the new lift height and will eliminate the lower ball joint which is the cause for 90% of "death wobble". The adjustable carrier bearing bracket isnt needed unless you have a truck that is getting driveline vibrations that cant be easily tuned out with shims. It makes the process easier but alot of times some simple cheap shims will do the trick. The heavy duty draglink isnt really needed until you get up to 10"+ of lift. Its a solid setup that replaces the factory weak draglink. A good upgrade for any truck but again, not a needed item.
Wow, Thanks for all the info, def schooled me. I started to google some and learned a bit from that but you've helped out alot. Let me get some things straight and I'll def hit you back, which is easier through here or call? Im still In Iraq but will be out of here in a few weeks.. let me know what all I'd need to do to get things rolling.
Before you talk about to carrier bearing drop piece, you may have someone crawl under their truck that's an ex cab long bed to see if you've got one... My ex cab short bed does not have a carrier bearing what so ever.... And I assume thats from the factory. (Not sure cause I bought used...)
1 - 11 of 11 Posts
