1 - 20 of 38 Posts
any help would be appreciated
The sound of your stock turbos wastegate is non adjustable.
What you can do is unplug the red line that is going to the wastegate
Do you have gauges already I take it?
just unplug the red line its not worth wasting your time shortening it.
You can shorten the stock wastegate rod but you have to be very careful. If you are concerned about the gate opening early I would go with a turbo master from dieselsite. It is adjustable and much cheaper than a Banks bighead.
He will probably be getting a new turbo soon anyway. SO just unplug that thing and drive it.
Ya you get more boost but be sure you plug the red line off if you didn't know that already just put the line on an intercooler boot clamp stud. just thought I would mention the plugging it off part I have seen people just unplug it and let it lay.
Good to know DJM. What can I expect by unplugging it and is there any downside?
You can expect more boost.
Only downside is that anything over 24 psi you will defuel if your tuning isnt setup for it. And also a stock turbo wont last to long if it sees over that a lot.
I have an ITP boost fooler. I was told to keep the stock turbo under 28psi? Is 24 the max?
I beleve the stock turbo is rated at 24 or 25psi
When I had my stocker i would push it up to 28 - 30 but it didnt last to long.
unplugging the wastegate hose
Unplugging the pressure tube going to the wastegate is a bad idea.....when the wastegate doesn't open at all, the shaft speed of the turbo goes waaaaay up. To the point that the impellers could explode. The turbo and engine match are done assuming the wastegate will function; if it does not, the turbo rotating assembly design limits are exceeded. If you want more boost, you don't just unplug things. There's lots more engineering that needs to be considered.
1 - 20 of 38 Posts
