1 - 12 of 12 Posts
Hi guy's, how do you load the tunes from the memory card into the the Dashdaq? I'm not having any luck with the tranfer. Thanks.
From your email, attach your memory card to your computer, put the tunes in the transfer folder. If you do not have that folder, create it. If you first hookup the Dashdaq to your truck with the memory card in it, and backup the firmware it will also create.
After this folder is on the memory card with your tunes in it, put the card into your dashdaq, plug it into your truck, put the key in the on position.
Now on the dashdaq go to tuning, then load tune. You should be able to scroll through the 3 tunes you chose and then select load to load it. It takes quite awhile for it to load.
I hope this helps
Looks like the question was answered pretty dang well.
Hey guy's I've installed the three tunes onto the memory card and and installed the card into the Dasdaq. I then go to the load tunes icon and click and the tunes are not there.
Hey guy's Thanks for the help, I was creating my own folder instead of the tranfer folder that you create when you plug the dasdaq in. So I'm loading the 210 as we speek.
Is the 250 worth the extra cash?? Thanks again.
I couldn't tell you if the 250 is better or not because it is the first one I loaded and it kicks *** so I have not tried the lower ones yet
Dr. P,
Did you upgrade to the cat delete and add the larger injectors?
I am waiting on a call or email from SDT........
Mike
The 250 is worth every penny that it costs. The transmission shifts really hard and I can fill up a whole road with smoke. Even though it is 250 hp, I actually get about 5 mpg better than before because it keeps the motor in the low rpm's.
Dr. P,
Mike
I did delete the CAT also. I did not buy a delete pipe at all, I gutted mine because I got nervous at the thought of visual inspections here in California. Also, I have the stock injectors. My only mods are AFE air intake with torque tube, Spartan Tuner, and Magnaflow DPF back exhaust
I have not heard of any visual inspections being performed in CA. I know that we will have to smog these 08's in the future. Have you heard different?
I had heard rumors and so had my mechanic about huge fines for lack of having the equipment on their with a visual inspection. But, you know how rumors can be
I don't know about inspections, but if you draw attention to youself with a huge cloud of coal, then a fix it ticket would probably be in your future.
1 - 12 of 12 Posts
