1 - 11 of 11 Posts
Ok guys I need help I have a 6.0 and I'm pretty familiar with its short comings however I'm clueless with the 6.4. The thing is im in control of maintenance on an EMS service out side of San Antonio, we have a fleet of 4 6.4 ranging from 2008 to 2011 and we can not keep them on the road 3 of the 4 have new motors along with multiple other issue. The good thing is most of the work has been warranty work so it's been minimal for actual cost of repair however they are quickly moving to that 100,000 mile mark. If they keep going like they are they will kill us. My question is what upgrades can I do to make them more reliable/durable. Such as I know the 6.0 with the egr delete, ford gold coolant is bad, head gaskets are faulty ect ect. Pretty much our small life saving business needs help!!!!!
Thank you for any info you can provide
Jason
Delete ALL emissions dpf,egr, CCV mod. Follow severe maintainence schedule. Ford gold coolant is only bad if you don't monitor it. I've had it in my 6.0 and 6.4 I flush it lots and monitor it lots never had oil cooler problem my deltas are 4 degrees
Agreed the emissions is a killer! The DPF in your situation is probably not an option. I would just take into consideration that jack rabbit starts and sudden burst of acceleration will not help with keeping the DPF out of regen. Another thing is that you must put good fuel in these trucks there is a required minimum cetane rating that must be used or else you run into problems. Regular maintenance is crucial oil filters every 5000 and fuel filters every 15000 to 25000.
Your right about the fuel I add power service diesel kleen to EVERY tank. Also I wouldn't go 25000 on fuel filter. I've never gone over 10k miles. I know that's extreme but I've read and saw enough horror stories about 13g out of pocket repairs that it was enough to scare me. I thought with ambulances and vehicles like that you could get away with not running dpf. Don't quote me on that but I have heard it mentioned
Jason
What is going wrong with your engines?
Cold starts and hard throttle on a cold engine is hard on everything. Not letting them cool down is hard on turbos.
One thing I would suggest is plug them in Block heater yes even in the summer this brings the block temp up and helps withthe cold start and running.
Deletes will help with longevity DPF/DOC/EGR, intake mainfold to even air flow.
By-pass oil filter and Coolant filter will help also.
Runnign hard on a cold engine is yoru biggest issue but least controllable.
Emergancy vehicle do not get an emmission inspection, delete the emission stuff DOC/DPF/EGR. this will help control heat. A tuner is needed, run at stock or no power to keep things health for a long time.
You might want to schedule you maintenance a bit sooner as well,
5k miles to an oil change
10K on fuel could be inline with the oil change ( every 5K)
Transmissions fluid and filter 30K could be moved to 20K
Air filters each oil change
Fast Idle mod might be in the cards as well to keep from cold stacking (I don't think this is some much an issue with new electronic engines)
as said deletes are your friend, and I actually saw Nate from PTP post that they have sold mini max with multiple liscenses for fleets so you can tune all of them with just 1 programmer, I would call them up.
10k wow well i guess no fuel or lack of could really hurt. I do them every 15k? Are the filters just crap or what?
The frame minted filter isn't the best design but 10k filter change is a good idea considering the cost of the fuel system
those filters are just so expensive. I guess i better go get another set to make sure its kosher.
1 - 11 of 11 Posts
