1 - 7 of 7 Posts
Total noob... 2003 f350 4x4 CC. Towing loaded 3-horse last night. Loss of power and note that if I let it fall to idle, oil pressure drops to ZERO. Hard starting last night as well. Thought also heard like a 'shhhhhh' sound sometimes from passenger side. Limped it to a friends place.....
David
Sometimes, an HPOP (high pressure oil pump) failure can be sufficient enough to cause your symptoms and to cause the oil gauge (low pressure oil) to not register a pressure.
Yea...... got it to the shop and just talking to them they mentioned HPOP and something about a blown off boot or hose......
Thanks!
David
Diagnosis - it's the HPOP. Gonna have them do the EGR delete as well while they are in there.
David
How much will this job run you?
1 - 7 of 7 Posts
