I posted this on PSN and PSA but I figured I'd throw it up here too as I'm desperate for some help.
Quick run down of my truck's problem. Mods are in sig.
The truck started having a miss at idle and low rpm about a month ago as well as what sounded to me like "injector knock", so I replaced the injectors with a set of rosewood 160/100's and also installed an adrenaline hpop and intake/pre-pump kit new vcg uvch and orings on the entire fuel system, as well as some beans custom tunes. The truck had kinda of a slight miss and just general rough running. I assumed this was just because of all the air in the oil and fuel system so I really didn't think much of it. However it has now been over two weeks and roughly 400 miles and the truck has actually gotten worse. It has a horrible miss which sounds to me like it may even be on multiple cylinders. At first I thought it might be a tuning issue as some tunes seem to run worse than others however I changed the oil this past weekend and also had the drivers side vc off just to take a peak and see if maybe an injector plug wiggled loose or something. After I changed the oil(and with the driverside vc still off) I started the truck and it ran much better. It still had a slight miss but sounded much smoother and didnt stumble at start up. So I turned it off and was tinkering with my driveshaft for a bit, then when I went to leave it started running like $h*t again. It being intermittent and slowly getting worse tells me it isn't the tunes so I assumed it must be an electrical issue, so I pulled out the multi meter and ran the resistance tests as per thie service bulletin http://www.gbreman.com/docs/techbulletins/GB_Tech_Bulletin_103_Ford_IDM_Replacement.pdf
and everything seemed to be within spec
Drivers side
(inj#2)3.6ohm
(inj#4)3.7ohm
(inj#6)3.7ohm
(inj#8)3.6ohm
Pass Side
(inj#1)3.6ohm
(inj#3)3.6ohm
(inj#5)3.6ohm
(inj#7)3.7ohm
I'm stumped and don't know what else to try. Heres a video I made yesterday after work. I need this thing fixed it's my DD and I don't like driving it like this but don't have a choice. Sry for the essay just desperate for help.
do you have a code reader?
if not get the codes read.
could be bad ICP sensor, Bad IPR, or possibly cam sensor.
but the best thing would be to read the codes
Not getting any codes other than intake air temp and epbv.
Just put a brand new ford icp sensor in today and a new cps yesterday. no improvement. The IPR is the original one but I cleaned and inspected it when I reinstalled it and it looked and functioned properly
