1 - 8 of 8 Posts
PMR = JUNK
How do i make the homemade IAH delete with a boost fitting? The search on this site isn't the greatest.
I believe the thread is 22x1.5 mm if you have access to a lathe. I made my own on a lathe. You may be able to buy one some where(plug). I heard that an OEM oil pan drain plug from some vehicles ( i believe it to be some Chebbys but don't hold me to it) is the same thread and size.
PMR = JUNK
I was hoping to buy a plug, i dont have access to a lathe
Ok, I'll look and see if I can get you a link right quick.
PMR = JUNK
Anyone else. I probably have a bolt around here that i could use if i knew the drill and tap sizes.
itpdiesel.com has a plug with or without the boost fitting for 9 bucks! couldnt findn you an exact link but i know its on there
PMR = JUNK
Discussion Starter · #8 ·
No need to post any more, i did some searchin and found what i needed. Thanks anyway.
1 - 8 of 8 Posts
