1 - 20 of 31 Posts
I just cut open a coolant filter after 15k miles and had over 1/4 cup of casting sand and junk in it! I changed my first one at 10k of usage and it had nearly the same amount! I can email pics to anyone who wants to post them for me. I can post them from my phone.
I'll pm you, i'll post em.
Holy cow, is right!
Are you monitoring deltas? What kind of coolant filter are you running?
I run the filter from diesel site.com I have the edge CTS and my monitor my deltas. I was seeing 10-15 unloaded and 30+ towing. I just replaced oil cooler and installed a bulletproof EGR cooler last week. The filters are the Baldwin ones. I ditched the gold for cat ELC this time.
damn! glad im running my coolant filter too.. i run the napa 4070 filter. First time i didn't get much for casting sand though.. prolly because i did the flush shortly before it
I'm waiting on my coolant filter, been on backorder for a month, supposed to ship monday. I've got 24° delta after a serious tap water and distilled flush. Refilled with elc.
So you got that amount of crap in your filter before or after you switched to ELC?
War is the answer!
I did a compleat and thurow flush less than a year ago also changing out my oil cooler but I changed my coolant filter out today and holly sh1t was there a lot of crap in there.
Sent from my GSIII on the Blazer ROM LF8 Radio.
Lets see some pics!
Reverse flush or don't drive it!
War is the answer!
a reverse flush isnt going to cure his problem. as long as you got rid of your egr cooler then you are ok just keep your oil temp below 250* or you can ruptur your oil cooler. Also I wouldnt wait forever to change out your oil cooler and coolant flush. It needs to be done if your deltas are that high. Anything over 15* mean your oil cooler is bad.
What is a charged filter? I just used the ones that came with the diesel site kit.
Charge with sct tablets, napa 4070 is non charged. Can't remember baldwin, whats your number. You don't want charged.
War is the answer!
I use 4070.
Sent from my SPH-L710 using AutoGuide.Com Free App
1 - 20 of 31 Posts
