CAN SOMEONE GIVE ME DETAILED INSTRUCTIONS ON ADDING THE HIGH IDLE MOD TO MY 2004 PSD. THANKS IN ADVANCE!
the high idle mod activates the PTO circuit in the "customer access" wiring group under the dash. im not sure that the X has it or not, not being something typically using the PTO function, but if the wires are there, then I dont see why it wouldnt work :dunno:My 03 Excursion has always run up on high idle by itself (depending on cold temps). Is the mod additional too this.?
Here ya go. A buddy of mine did his X http://www.powerstroke.org/forum/6-0l-ford-excursion-discussion/40457-6-0l-excursion-seic-mod.htmlI wonder if it would work on the Ex? I guess I would have too see if the tech file directions are the same wiring as mine.
