1 - 5 of 5 Posts
well it started out that i had no boost so i put a 38r and then started missing so i put two new injectors in and seemed to be work well and started to build boost at 1800 to 1900 rpm then i started to boost it and i blow the cold side ic pipe off now i dont start to build boost till 2200 to 2300 rpm and last night i was puling around on the high way with a bmw and i was doing good till my egts hit 1400 WHAT DO I DO
Discussion Starter #2
bump bump bump
bump bump bump
Check your intercooler boots and up pipe donuts. Sounds like youve got a boost leak somewhere yet
1 - 5 of 5 Posts
