1 - 10 of 10 Posts
Hey RS,
I ordered a set of projector headlights, seen here:
SPYDER® - Ford F-350 2008-2010 Smoke Halo Projector Headlights with LEDs - SD
I didnt order from there, and told they are Sonar ( I think they are the same as spyder?)
Regardless, I asked which bulbs they take and was told H1 for both hi+low beams.
I know I want 5000k colour, id also prefer 55w but im reading mixed thoughts on whether they are too hot for housings?
And Im in Canada so curious on shipping options.
Thanks!
Hey RS,
Thanks!
For the after market lamps, the optics are generally not designed very well, and on some versions for some makes/models they will focus a spot of light down right where it hits the front cover of the lamp housing. With 55w we've seen that little spot of focused light end up causing the area to melt or deform. For that reason we recommend the 35w when it comes to the after market projector lamps, just to be cautious.
To avoid any confusion and possibly someone coming across this thread and ordering the wrong stuff for their vehicle, we'll send you the links and selections for your specific setup via PM.
Hey,
Thanks for the quick response, also got PM.
I will go through the links after work today and hopefully get ordered by tonight/tomorrow. I will go with the 35w to be safe as well.
Thanks!
Hey Todd,
Just placed order online. I think I got everything right. Order id# 24208
35W DIGITAL HID KIT for Head Lamps
Bulb Fitment:H1
Bulb Color:5000k warm white
Vehicle Application:Other (+$0)
Ballast Type:Regular (all in one)
Bulb Capping?:No Thanks
Relay Wiring Harness HID and Retrofit
Bulb Type/Fitment:Universal
Capacitor Linkage
Select Fitment:Universal Harness
Oh, I forgot it wouldnt let me select bulb capping for some reason, when I selected it it faded out the "buy" or "add to cart"?
Not a big deal I guess.
Thanks!
Clayton
Hey Todd,
Bulb Fitment:H1
Capacitor Linkage
Thanks!
Clayton
That looks to be exactly correct there. The bulb capping it will not let you add because its not needed with that bulb type in any situation really and if it was added the bulb would then have a big fitment issue as well.
Thank you for the order and that should be on the way very soon if not already.
Awesome! Thanks again.
Hey, I dont have my order id anymore and cant access any instructions! Can you help me out please?
Thanks.
1 - 10 of 10 Posts
