Thanks to recommendations made by Mor4wd and ups 6.0 I am looking into the HID headlights for my truck. The issue that I have is that being in Canada I have to run the daytime running lights. HID lights apparently cannot be run on low voltage so the HID kit accommodates that by putting full voltage to the lights all day. I'm not sure on the Ford trucks, but some vehicles use the high beam at low voltage for daytime running lights. Would I be inadvertently shining my high beams into oncoming traffic during the day with these lights? Any other concerns that people have with these kits?
For the daylight, You will have no worries about shining people.
Just a note if you are installing them yourself.
Cause of the DRL, it sends 50% power, it actually continuously pulses ON/OFF, instead of sending 6~Volts. Depending on the Hi/Low Relay that comes in your kit, it will toast it pretty fast. I blew a DDMTUNING one in a week, because the relay will continuously click. There is 2 options around thisthat I am aware of.
1) Cover the light sensor on the dash (makes your truck think its nighttime all the time, And leave the switch on auto. *Keeping your headlights on all the time - Only downside is it dim's your dashlights.
2) Or hook the relay into your parking lights instead - requires a little wire extension and tapping.
I went with option one out of sheer simplicity.
If I am wrong about how the DRL functions feel free to correct me. Just going off what I have been told once.
