I need some advice with the HFCM in my 2005 F-250 4WD Diesel.
I just replaced the fuel filter and tried to re-install the water separator drain plug. It looks good, but it will not tighten. It threads on loosely but keeps spinning. As I can't seat it, I assume it will pop out when driving.
Answers to following would be a big help:
When I removed it, a half circle of steel came out in the plug's threads. I am assuming that this is a broken thread from inside the HFCM threads. This sliver of metal is not an engineered part by any remote chance?
Am I right to assume that the only way I am going to fix this is by replacing the entire cover of the HFCM?
Can the cover of the HFCM be swapped out with the drive shaft in the way, or will I have to drop that first?
I see part number 6C3Z-9B249-A at Amazon for $118. Is that the one I need, or is that more than I need?
If I am to replace the entire cover, could I try a temporary fix by permanently sealing the drain plug in place with some JB Weld?
Any other relevant advice from someone who has replaced a HFCM cover would be much appreciated.
Thanks,
RR
Thanks,
RR
