1 - 20 of 26 Posts
Whats the number for the dome light fuse and which one is it .. I poped mine putting in my recone dome lights .
Any info would be great thanks
2006 F350
Checked all fuses mothing wrong . Took cables off bat for 10 mins nothing . Something about the 30A breaker how do you reset that ?
cant get my windows up.........
If its the 30a breaker it will reset when it cools off. Cant remember off the top of my head which fuse the dome light is though. I can look in a bit though if no one else posts it
how long to let it sit before it resets?
been 20 mins still nothing still cant roll up the windows and no dome light
If i could get the windows up that be great but no power to them ..
That's what you get for putting in those :supergay: recon lights, you should of gone ahead and did the the door sill's with that stupid "super duty" light up strip to (if you havent already). The truck will be much faster and cooler once you get those!:hehe:
LMAO........
Are you kidding??? That was completely pointless, useless, and rude :doh::dunno:
You checked all the fuses? Under the hood and the dash ones?
i think its the same,my truck is an 07 .try fuse #29 customer access its a10a fuse
yes all check all good . The 30a breaker is getting no power to it.
or you could try fuse#42 delayed accessory or relay#306 delayed accesory
Discussion Starter #12
I went double check 42 good and 306 is a relay not sure how to check it
Discussion Starter #13
Anything else guys ? How long for a breaker to reset ? Or is there a way to reset it ?
Discussion Starter #14
shot in the dark here guys will the sct show any codes ?
Discussion Starter #15
:bump::dunno::dunno:
SCT wont show codes for that. Either you blew a fuse or killed that breaker
I did this a few weeks ago installing my AMP steps. it is a 10A fuse under the dash. what is says has nothing to do with the windows, etc. let me find my thread I think i mentioned the fuse #
ok, here was my last post in that thread
just an FYI, found the problem. there was a stupid 10A fuse labeled 'Instrument Cluster' that had blown. All good now
check that one out, not sure of number, but it is in fuse panel in truck not under the hood.
Discussion Starter #19
Great thanks !
Discussion Starter #20
Thanks man that got the windows to work and radio back THANK YOU THANK YOU Doubledrop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1 - 20 of 26 Posts
