2002 F350 4x4 Help Electrical!!!!
Prior to the following the truck was running and starting fine and I was listening to the radio all day while doing the mirror install.
So I was finishing up my 08 mirror install and decided to pull the stock radio to clean up some wires hanging under the dash for my Sirius sat radio, well when I was pulling the radio, realized I needed to pull the dash bezel, which i did and unhooked the headlight switch, 4x4 switch, and aux power. I did all of this with the ignition turned to the on position so I could lower the gear shiftier on the column. Well in the middle of this I lost power and could hear a fast clicking coming from the fuse box so I opened the fuse box and this relay (see pic) was the one clicking. When I pulled it the clicking stopped but still no power. What do you think I did? Should I replace the relay or check other things. I don't want to screw any thing else up.
hnoes:
hnoes:
