1 - 7 of 7 Posts
The old yellow o ring under the HPOP just fell into the motor. Went right past the cam what should I do now??
Discussion Starter · #2 ·
Well I got in a hurry because the wind picked up and there was a bunch of crap in the way of the garage door. Tried to hurry up and get the HPOP back on, well the yellow o ring under the HPOP popped off and went right down the motor. I think it should be ok but what do you guys think. It will probably stick to the bottom of the pick up tube.
:bump: any help much appreciated
War is the answer!
What do you mean? Is it in the oil system?
Sent from my SPH-L710 using AutoGuide.Com Free App
No its fell somwhere under the cam, under the HPOP. I had the HPOP off replacing the stc fitting and when I was replacing the o ring it popped off and fell right in the opening to the cam can't see it any where.
War is the answer!
I wouldn't worry about it. If anything it will just get chewed up but it's soft so it won't hurt anything. I once dropped on down the intake....never did find it but it didn't hurt anything thank God.
Discussion Starter · #7 ·
Thanks, that is what I am hoping.
1 - 7 of 7 Posts
