1 - 10 of 10 Posts
Ok i have a 2000 7.3. Pulled out of parking lot today from work ran good made it a couple hundred yard then lost power idles rough lower power in the lower rpm range. No check engine light but the service engine soon light came on. Plz help im out of state my wife is flying in sunday i have no other way to drive the hour and a half to pick her up. And have no way to work. Truck will start and idle just really rough. It will drive and i can get it up to speed, but slowly. Runs a little better at higher rpms like 2500+ but not much. No smoke no over heating, good oil pressure plz help!!!!!!!!!
Maybe check the fuel pump! Sorry for your troubles I hope you can get it figured out!
Sent from my Autoguide iPad app
also i need to know bad enough, if you have any idea what it is call me. 417-228-0007
i drove it like this for about 15 miles had to get home, so not sure a fuel pump would have it idle rough and keep up with fuel at 70.
No mods other then an edge chip.
My buddys fuel pump went out and the truck would barley idle and it would just creep is about all it would do..you could look on top of the motor and unplug your value cover gaskets and see if it looked melted at any of the pins i have heard guys say that sometimes when they mess up they melt at the plug but thats just a idea i maybe wrong but it wouldnt hurt to look..does the edge read codes off if your truck i haven't ever messed with a edge on a 7.3..
Sent from my DROID X2
i found out that one of the injector plugs came loose or something like that. Started the truck this morning and it runs perfect with now service engine soon light so i dont really know whats goin on. But from what i have found searching the net, the injector plugs come loose.
Check the diaphram in the fitting where the fuel line goes into the pump. It may have some trash in it. It's a simple fix, after you remove the fuel line, there are two hex head screws to remove and you're there.
got if fixed the main cause of the missing was the injector plug going into the valve cover, the plug had came loose some what and burned the pins up in it.
I'm surprised that wasn't mentioned sooner.
Usually UVCHs are the main thing.
I've rarely heard of the fuel pump diaphragm being dirty. Usually it's the pickup foot in the tank.
1 - 10 of 10 Posts
