How do I get the front rotors off? Or at least what's left of them.
Calipers and caliper brackets off? if so, sounds like the rotor is rusted to the hub... bust out the oxy-acetelene torch:nod:
What a ****ing pain. That damn hub nut is a *****.
OBS trucks are a little different than the SD's. Take off the caliper and bracket, then take the 3 screws out and pull the locking hub caps. 2 small screwdrivers to pull the lock ring out of the locking hub, then thread a cap screw in and pull the locking mechanism out. Remove the hub nut, the lock ring, and the other hub nut, then pull the rotor off.
