So my headlights randomly stopped working, truck was then parked for a couple weeks....before starting again i went through and checked all the fuses, started the truck and turned the headlights on and they worked fine. Drove for about an hour and then they just randomly turned off and wont come back on.
Used volt meter to check the underhood fuse location, the constant gets 12.6 volts, when i turn the switch on the left and right side fuse locations are getting 12.6v. Both lights and foglights are not working
Next?
Next?
