1 - 5 of 5 Posts
Just picked up guages and not sure where to tap in for both pyro and boost... Please Help
hmm. Not too sure on the boost. I'm sure the 6.4 still uses a map sensor. You could tie the boost into the map line. the pyro you can tap the driver side exhaust manifold.
wouldnt mess with the map line..tap the intake elbow..just like you would do on a 6.0
the EGT gauge just tap one of the manifolds.
Has anyone found a spot thats easy to access in the manifolds for the egt's? Or does it require removing a wheel well?
1 - 5 of 5 Posts
