1 - 5 of 5 Posts
:confused::dunno: i need some help, im getting some codes in the truck, first the truck is a 2004 4x4 crewcab 6.0, the codes im getting are p0113 IAT sensor,p0488 EGR i got the egr blocked, p0603 memory ram?????,p1102 maf sensor to low, p1335 EGR, p2290 inj ctrl press too low, im ting to fix this codes, where can i star??? where is the IAT sensor located???? and where can i find it cheap???? next is the maf sensor can i just clean it or buy new???:( im getting horroble MPG about 12 and i was getting about 19, the only mod that i did was selling my bully dog and got a SCT with custom tunes from DJ..... can any one help to get a better MPG:confused: thank you for your help:)
start by cearing codes and see what comes back, definitly have a egr valve sticking open, thats the p1335 code , the iat sensor is mounted in the intake , dont buy anything other than a egr valve , clear all those codes and restart diagnosis , then see what codeds come back, the p0488 code is possibly even a code that shouldnt be there , there was a reprogram to eliminate that code all together awhile back, truck may need the latest calibration
thank you for the quick respond, i did blocked the egr, will that has something to so with it, i but a freeze plug in the exhust side, i did erase the codes and the ones that came back are the the iat sensor and the p1335 egr, is the iat sensor togeter to the mass sensor????
just because the egr is blocked doesnt mean it still cant cause problems , that is a big misunderstanding ,boost pressure can still push it open on the boost/or intake side of it , the iat sesor can interfere with mass air flow readings , there is also a iat in with the mass air flow sensor mounted in the intake , they are not known to give much trouble but can
you think, maybe if i change the MAF and see if it works?????
1 - 5 of 5 Posts
