I have a vibration in the front of the truck that was VERY loud and vibrated the steering wheel, almost deafning is so loud. It only happens between 50 and 65 mph and it is speed dependent and accelerator dependent. When I push the gas it to accelerate I feel the vibration if i let off it mostly goes away. Now I know that I HAD a bad steering stabilizer at that time, I was hoping that when i istalled my new dual stabilizer setup that it would help the problem, also it got new ball joints and u-joints and I pulled the front drive shaft just to rule it out. It got an alignment and balance with the new tires and the entire suspension is new. The dual stabilizer setup did reduce the vibration greatly but i can still feel it and definitely can still hear it btn 50-65mph. Oh yeah i also installed a new steering box too. Basically the same vibration before all the work is still there after all the work and the dual SS did reduce but didnt eliminate it. Anyone have any ideas of what to try or investigate next?
Wheel bearings were checked when doing the front end?
I would then try rotating the tires and see if the vib moves to the rear of the vehicle.
It gets worse when you are accelerating?
Hub bearings are tight... Wheels and tires are brand new and vibration was there before I replaced the wheels and tires... When accelerating I get to 50 through 65 mph I feel the vibration... But let's say I'm going 62mph and I let off the gas the vibration IMMEDIATELY STOPS... Then as soon as I touch the gas pedal it IMMEDIATELY STARTS vibrating again
Ok, saw you pulled the front driveshaft to see if that helped but did you make sure the hubs were unlocked? Not just if they are in the unlock position but actually disengaged?
Sounds like it is drivetrain and since you said it is in the steering wheel, its most likely in the front end.
Is the vibe a fast frequency or slow?
Seems like a quick vibration... The bearings did seem tight by hand when I replaced the hubs out for warn hubs. Correct me if I'm wrong but to test if axle is engaged I can Jack up the front end and engage the hubs and both tires should spin then disengage the hubs and they should spin freely independently of each other? I did have both shafts pulled and I changed everything out except the wheel bearing... U-joint and all seals. Could u explain the significance of the shaft engagement?
I was just pushing the idea of actually verifying the hubs are disengaging. Some guys would go look and if the hub is pointing at "free" then they think it is unlocked. It should be, but doesnt always mean it is. That was what I meant.
Yeah, you can jack the front up . Then slide under and rotate the front driveshaft by hand (engine not running) to see if the tires spin or not. Engaged (lock) should make them spin and so on.
If it is a fast vibe then that is usually before the axle like (and not meaning they are bad) trans, transfer case, dirveshafts. Could it be coming from the rear shaft?
