I'm having some issues when the trucks at idle.
Real choppy, lopey idle, almost stalls out
Throwing the ses light
NO POWER @ idle
*it is not all the time, intermittent problem*
I know I need to get it on a scanner hence the ses light but being in college pt and working pt it's hard to find time.
I'm going to start by checking all sensors for a snug connection as for what to do after that I'm lost??
Anyone expierienced these symptoms? Any help is appreciated thanks
see if theres oil in the icp, make sure battery cables r tight its a start anyway
i had the same thing happen to me, it was the ICP sensor. mine had oil in it and that is a key sign that it has failed. also once i installed the new one it did it to me again, but it was just the connector being loose. good luck.
After checking my icp it was not firmly seated on the cup. No issues yet
