1 - 20 of 31 Posts
Ok so back story is I just bought the truck and I don’t know much about it. The lady I bought it from didn’t know much either. I got it home threw some good spare batteries in it and got it too fire up and I heard this knocking. Sounds like a spun bearing to me but I wanted to get opinions from you guys who are a little more knowledgeable than I.
Get a good scan tool on it (like ForScan) and check for codes.
Bismic, there’s no CEL when truck fires. I have a SCT X4 in my daily that I could pull out and try to pull codes with. Do you think that’ll suffice?
These are the codes:
P0403
P0405
P0672
P0678
These are the only 2 I would think is cause for concern, crank and cam sensors.
P2614
P2617
Communication Device Portable communications device Gadget Font Mobile device
Hopefully the new buy proves to be an asset.
Try a stethoscope and probe around see if you can pinpoint the noise. That sure seemed to help me.
I’ll definitely try that I have another engine I could just throw in but if this one is savable I’d like to try and save it!
Time to pull the engine -- tear it down and see if it is worth fixing
You may find something simple like a broken flex plate -- that would be great and easy
tho, it may indeed be a rod bearing or something on top of a piston
let it run for a minute, pull dipstick and see if the oil is shinny. Or drain the oil and see. Run a magnet in it and see if it pulls anything. If the oil is good, then look at external parts, like flexplate.
The first thing I would do is to use the starter connector on the passenger firewall to the positive battery post and record how it sounds so we can hear it better. It may be it has a bent pushrod or broken rocker; both can be fixed without taking the engine apart. It's worth a shot before yanking a motor.
Discussion Starter · #10 ·
Agreed! Oil is full of glitter
Discussion Starter · #11 ·
Even if the oil is full of glitter?
Discussion Starter · #12 ·
Did run it, flashed low oil pressure on dash not much metal on dipstick but I pulled the filter and it’s full of glitter… tried magnet (small fridge magnet, pulled nothing).
Discussion Starter · #13 ·
Not that it matters, just a fun thing -- use a neo magnet and pass it close over the oil surface in the drain pan -- watch if the particles try to follow the magnet or not -- follow= ferrous -- no follow = aluminum
Reactions: 6OhNoob
Discussion Starter · #16 ·
Rookie question what would be which lol
Gonna have to explain your question a little more, like what are you asking about?
Discussion Starter · #18 ·
If it’s aluminum what would it be vs if it was ferrous what would that be.
just so I know what ALL I need to be checkingas I break it down. I will be checking everything but just wanted to know what I should make double sure to check in fine detail.
AL would be pistons or HPOP most likely
FE would be crank, cam, that type of damage
Neither of those can be fixed without a tear down , except the HPOP, but that is unlikely
with that much metal, I don't think you will have a hard time recognizing the failure
Reactions: JustinOOO9
Discussion Starter · #20 ·
Agreed I don’t think it’ll be hidden …
1 - 20 of 31 Posts
