1 - 20 of 34 Posts
a truck
Hey guys so here is the problem
Truck was running fine all day, nothing seemed wrong drove it all of 60 miles today for work and no problems. I was going to be driving up to wisconsin tonight so I stopped to get diesel after work. I filled up and went to start the truck and all it did was crank. It will not start but it does crank. Im guessing its a fuel issue, I checked the fuel and diesel was definitely in the pump, they didnt screw up and put gas in the diesel pump. Everything else seems to look fine but it will not start. I just got it towed back to my house and have no idea what is going on
PLEASE HELP!
have you check to see if you are getting decent fuel pressure?
ok, just to make sure. check oil level in your hpop. mine wouldnt start one time and it was because the hpop was low.
there is a plug on top of the hpop. take that out. oil level should be within 3/4 inch of top.
CPS? are you getting a wait to start light?
a truck
ok thanks, one more question and I am going to sound like a total newb here, but where exactly is the hpop located?
a truck
Yeah Im getting a wait to start light, would I not be getting that if it is the CPS
ok, hpop is located in front of of fuel filter housing, to the right of your alternator. and while it is cranking does the rpm gauge jump around?
a truck
Discussion Starter #11
Thanks I know that was a dumb question
Also the tach doesnt jump at all so I dont think its the CPS
no prob. the only dumb question is the one not asked man
the tach doesnt jump? this means your cps is bad. it should jump if cps is working
a truck
Discussion Starter #14
Oh sorry my bad I typed that wrong, yeah it doesnt jump at all, so can they just go out like that just suddenly
all the time, with out notice. usually just die while going down the road. i keep a spare in my glovebox at all times because it is a common problem.
yes 10mm socket, 1/4 inch rachet, small extension. i also keep that setup in my glovebox at all times cuz you never know when they will go out. i suggest when you go get one, buy two. cuz it will happen again. they are around thirty dollars from ford if i remember correctly
a truck
Discussion Starter #18
thanks a lot man I really appreciate all the help, one last question where exactly is the CPS located
it is located underneath the water pump pulley. if you can look in the 7.3 tech files there is a write up on it with pictures. tells how to remove and install. let me know if you have any other questions. i'll keep checkin in. sounds like for sure it is your cps. pretty easy and inexpensive fix. but if not, let us know man.
1 - 20 of 34 Posts
