1 - 11 of 11 Posts
I have a 2006 6.0 F350 that won't start. It will cranks over good. It ran in the evening, smart for the night and wouldn't start in the morning. We can hear the fuel pump. The FICM is good w/ 48 volts out. We replaced the ICP and the IPR with no results. Just had the oil, oil filters and fuel filters changed 700 miles ago. Any suggestions?
glow plugs or ficm, first get it scanned...I know its tough in a small town but still need to get a real scanner on it and see whats going on. To many variables.
Reactions: ScottF
Yes, the oil pressure gauge does move. The tach gauge moves as well. Also, the glow plug indicator lights up as normal. Can also hear the fuel pump ticking.
OK, so it sounds like the most likely issue will be a high pressure problem. It could be a leak somewhere or maybe the STC fitting on the pump. Either way its going to require more definitive test procedures and most likely a scan tool to try and isolate the problem.
1 - 11 of 11 Posts
