1 - 7 of 7 Posts
I just put 20" rockstars on a 2006 F250 with 35 discoverers on it. According to the charts the offset should not rub. The tire shop that installed them says it shouldn't rub. However, I am getting some rubbing on the left mudflap in the front. Is it acceptable to remove or cut the front mud flap? Thanks for your help!
Mud flaps are not necessary they are an add on. The charts assume the truck is stock and thats without mud flaps.
I guess mud flap was the wron word. Its not aftermarket mud flaps, it is just the plastic inside the wheel well...What are those called? Are they needed?
DO NOT CUT IT... take a heat gun and use a object the size of the area its rubbing heat the area and mold it out of the way it will look alot better
you didnt mention how much lift you are running.
1 - 7 of 7 Posts
