1 - 8 of 8 Posts
I can't seem to find instructions/ photos/video on removing a double din aftermarket radio that is clipped into the dash panel. I find tons of instructions on removing the factory radio. Current radio has the Metra 95-5817 kit.
You have to pull the entire dash face plate, sorry
Sent from my SM-G960U using Tapatalk
Depending on how it's installed, the above are correct. Follow the link to see someone remove the dash face.
im having the same exact problem, find an answer yet?
Did you even watch the video above your post?
the video above my post is not relevant to the bracket the guy asked about, the metra 95-5817 kit locks into the dash piece and makes it impossible to remove either the radio or dash...
Administrator
So I'll take that as a yes.
you have to pull the dash to get the kit out
1 - 8 of 8 Posts
