I have a rear block lift but the front end of my 06 F350's front end is a little higher...(13"gap from tire to flare in front 11.5" fap from tire to flare in rear) Would I be able to use airbags to level it out? would that stiffen the ride too much? or is there a better way to get the extra inch and a half? Any advice would be appreciated! Thanks :)
Air bags would lift it but would ruin the ride. If your blocks aren't too tall you could get something a little taller, use taller springs or replace the shackles/hangers. How much lift are you running and what are you using in the rear?
It is just one big block in the back. If I used shackles to lift 1.5 " additional would that be fine?
Try measuring from the from the top of the tire to the body line, I believe that the rear wheel openings are a little shorter than the fronts. If the rear opening is an inch shorter, this would explain your numbers. Personally, I always stepped back and examined either the running boards or how the body line flowed.
