Hello members,
I have a 2004 F350 Dually the other day my overhead display just shut off. Its the one that has the compass in it and lies everytime you fill up and says your going to get 800klm to that tank. I checked the fuse still no worky. Any suggestions ?? Please help
Thanks Vito.
pull it off, pull kinda hard.
then take out the three screws.
once you have it off shake it. if you hear something banging around inside then be careful when pulling it aprt to not drop anything out of it. there is a resistor loose inside.
once you have the circuit board exposed find where the missing resistor goes and solder it back on. youll need a soldering pen and fine solder.
if nothing is loose be sure to check all the resitors for good connection to the board. there is more than likely a loose one. just solder it back down and your good to go.
I had to RUB LIGHTLY( THE RESISTORS) and two fell to the ground soderd them back on and to my amazment it really does work:nod: tried to get you the link to the write up but comp illiterate.look in the mod/tech files:thumb:
