Was driving my 03 and out of no where is started to sputter like i was running out of diesel (truck said i had 22 miles to empty) so I cut it off went got diesel and when i got back put it in and turned the key and there was no prime sound or glow pug sound. What happened? Truck is all stock
Sounds to me like you starved it for fuel, and then the fuel pump burnt up. The distance to empty gauges aren't very accurate, especially when you are that low on fuel. In the future, once you get down to about 100 miles to empty, put fuel in it. If you let it get that low on a regular basis, it is destructive to the pumps. Most of them are cooled by the fuel that is being pumped through them. Once you start to starve them for fuel, the pump goes out rather quickly.
Cycle the key several times before cranking. You ran it out of fuel
Ok It was the fuel pump. Thank you for the input guys Im just new to the diesel game and learning while spending money haha
