My truck has been having a weird start behavior, especially when it's colder. I keep it in the garage, and since it's been warm, hasn't been an issue. But, the symptom is that it kind of struggles to start when it's colder, not like a battery issue where it turns over slowly, but more like it's trying to turn over but there's some resistance and it kind of stumbles, almost like it's misfiring in some way.
I assumed it was related to a few glow plugs being out, so this week I finished replacing the eight glow plugs, the two wiring harnesses and the GPCM. For the first time in about three years I don't have a check engine light, as the glow plugs are all good. I assumed that was the end of the starting issue.
Today I left the house early, and although it was not cold, it was in the 60's, and stumbled a little bit on the start. As soon as the engine warms up, it turns over super fast and starts perfectly. It's just when it's cold.
The two batteries are within a year or so old, and I did go for the AGM batteries. They seem good, and crank super fast when it's not cold.
I was doing some research, and some of the potential causes come up as glow plugs (all new), FICM (I have an upgraded one from FICMRepair.com, and it's still showing 50 on my Edge Insight CTS, and injectors. I assume my injectors are going to need to be replaced at some point.
Truck has about 184,000 miles on it
No check engine light or codes
I change my oil every 5,000 miles with Rotella T6
It has the revised stand pipes and dummy plugs
I was thinking about changing out the fuel pump due to the mileage, before it causes a problem.
Any thoughts, or ideas on how to troubleshoot to narrow down the issue? I'm worried that when winter gets here, I'll be screwed.
