1 - 9 of 9 Posts
I want to do a better shift kit so links and suggestions are helpful!!
Also probably will do a better valve body depending what i find inside this when i pull it....
Any other suggestions to help it hold up to the tw tunes and stage 1's??? My shifts aren't as firm as i would like and it seems to slip somewhat on extreme!
Thanks for your help guys
assistant director
john woods or bts valvebody
Do one of those. maybe a good TC
I got a triple disk TC.... whats a good valve body like that gonna cost me?? im doing a shift kit thats like $350
the trans go (tugger) kit works very well . i have had my truck back 8 days and cant stop driveing it
The trans go (tugger) kit would solve a lot of my problems by itself??? What exactly is in the kit and whys it so good?
when you buy a valve body from one of the tranny companies essentially all you are getting is a regular valve body with the trans go shift kit.
From what I've read Brian from BTS had a lot to do with the design of this version of the shift kit.
1 - 9 of 9 Posts
