1 - 13 of 13 Posts
Hey guy, I am currently going through my motor in my 2007 f350 6.0 diesel and upgrading all know problem parts. I have the motor out and have already pulled everything off including hpop and oil cooler. I am now in the process of putting everything back together and already have oil cooler and hpop back in place when I decided to drop the oil pan and found a 1/4" long spring and 1/8" ball bearing in the oil pan. I have looked all over and have no clue where these came from. Please help!
775588
06 6.0 drw 635 rwhp (retired) 08 KR build in progress
Check your hpop. Some had a ball staked in, I seem to remember having one of these fall out of a truck that came in with a no start, iirc it was an Alliant pump but it’s been several years I could be mistaken
I could be wrong, but I thought the ball bearing was bigger and unique to the 2003/4.
I would be concerned it’s a bearing in a lifter, but I thought they were hydraulic.
Anyway, a bearing for a lifter going through a HPOP will ruin it, so I’d proceed with caution.
Administrator
hpop bearing on the early units is like a sling shot ammo size
the lifters are needle bearings the rocker does have a ball bearing that size but no spring so I am no help lol
I've not come across anything like that disassembling my '03 6.0. What it might look like is a ball detent out of a socket wrench.
Reactions: Henry5105
1 - 13 of 13 Posts
