First, hello all. I have been reading posts on here for years to help prevent problems with my truck but this is my second post. I am going through several stages of grief right now, mostly shock and denial at this point particularly since my EOT and ECT deltas are relatively "normal" and have never been high. I think my EGR cooler may be busted and I'm looking for guidance on how to proceed. The trouble started about a week ago. I had a little white smoke out the tail pipe on startup twice last week but it has not repeated (detailed more below). I lost about 1" coolant level in the degas bottle after driving 250 miles. I was smelling coolant through the fresh air vent intermittently but only at a stop, never at speed. And I think I found coolant on the EGR valve last night (pictures below). Apologies for the long post but I'm trying to anticipate questions I've seen in prior threads over the years.
Vitals and Background: Original owner of an almost bone stock 2006 F250 CC Lariat 6.0L with only 65,000 miles. No tunes and never towed anything. Changed the oil about every 6k to 7,500 using Delo 15W-40. Only Motorcraft parts for filters (sourced from dieselfiltersonline). Motorcraft fuel filter sets every 15,000. Blue spring upgrade about 4k miles ago. Never any starting problems cold or hot. Has always run like a champ with one exception (turbo vanes freeze). I used a Scangauge II for the past few years and IPR and ICP look ok to me (like 582 to 604 ICP at idle with 22.6 to 24.2 IPR; and gets over 4,000 ICP pedal down--example: accelerating at 65mph yesterday I got 3695 ICP and 76.5 IPR (not full WOT).
Dealer did the first coolant flush with Gold. I installed a coolant filter at 55,500 (XDP with Donaldson filters). First filter wasn't very bad at all, very light. Second filter didn't seem to have much if anything. After educating myself on this forum, I got rid of the Ford Gold and its silicates. I did a complete flush with Restore and Restore+ at 60,000 and switched to the red Rotella ELC, with installation of a Fixur6 oil cooler backflushing device. At this flush, I replaced the upper and lower radiator hoses, the hose from degas to the intake, and swapped out the Y pipe hose to the base of the degas with a Mishimoto metal Y hose. New MC thermostat. I used Fumoto valves at the block drains for the flushing.
Turbo Problems. The turbo has been rebuilt or replaced by the dealer several times under warranty (I bought two Ford extended warranties). According to the most recent dealer, I babied the truck and did not drive it hard enough. CEL and underboost code P0229. Dealer "rebuilt" the turbo with a new unison ring and installed an updated oil feed line and return line (I can see a hard oil pipe in the front). That was 2.5 years and 14,000 miles ago. The diesel rep told me I need to flog the turbo and "drive it like I stole it" to keep the VGT vanes and unison rings from getting stuck with corrosion. I've been trying to go WOT up a hill or something almost every time it goes out to exercise it more.
ECT/EOT. Since I began using the Scangauge, my temps have looked "normal" to me according to what I've read. If I'm running on a relatively flat freeway at 65 to 70mph, my ECT is usually in the low 190's and my EOT is typically 8 degrees higher. If I do some hard accelerations uphill with the AC on, I might get a 10 to 11 degree delta with the highest temp ever of 215, and then as I level off the EOTs lower back to the former range. Once I get off the freeway, both temps come down with ECT dropping to 190 or 191 and EOT at 197 and dropping lower at a light. Driving on the freeway yesterday doing about 60mph on a flat, EOT 195 and ECT was 201 with outside air of 93 degrees and the AC on max. Before startup yesterday with truck sitting overnight, my ECT was 85 and EOT 87.5 (consistent with outside temps). My truck has always lived in SoCal and has never seen air temps below the mid 40's.
Start of the Problems. Now starts the painful part. Have not been driving much during quarantine but tried to take it out on the freeway once a week regardless. Three weeks ago I was on a super long uphill grade (about 15 miles) and noticed my temps were higher than usual, 211ECT/215EOT doing 75-80 with AC on. Immediately dropped back down once I got off the freeway so I wasn't too concerned but those are the highest temps I've seen on the truck. About 10 days ago I was on a short drive on local roads and headed uphill at 30mph. I gave it gas and it was obvious the turbo went "blah" even when floored--it lagged horribly instead of boosting. Sluggish as hell until higher rpms, then it took off. I kept driving it and it repeated several more times. My gauge showed a pending P0229 code. I decided to do some runs at WOT up some local road hills. Short bursts like 8 seconds. The turbo started responding again. I took it out onto the freeway and did some more runs (60 to 80mph). Since then, the turbo has kicked in like a champ and I have zero hesitation problems. VGT and Boost now rise and fall like I think they are supposed to. No more pending P0229 code. The max boost I could get (unladen) was 24psi.
Puff of Smoke. Fast forward to last Friday. I drove 45 miles on the freeway and it ran great. Parked the truck for about 75 minutes then started it up. I noticed some wispy white smoke from the tailpipe as I was standing there. It was very light (not a huge plume), it dissipated quickly and it stopped entirely in about a minute. Short drive around the block with some idling at a drivethrough and parked it again for about 3 hours. Started it up and no smoke. However, about 1/2 mile down the road I stopped at a light and noticed whispy white smoke blowing past the car on my right. She confirmed it was from my tailpipe. I pulled over and it continued to lightly smoke for a couple minutes then it went away again. Could not smell anything in the smoke.
Engine oil was black and at the max line. No frothiness under the oil fill cap. Zero puking out the degas bottle. Zero observable coolant leaks anywhere. Nothing under the truck or under the hood. Coolant in the degas bottle is clear red with no debris observed.
I drove it another 35 miles to a friend's house who is an experience mechanic. There was zero smoke and zero other symptoms at this time. Started it several times after letting it sit for an hour then two. No problems. He thought with no repeat smoke and no other symptoms it must be condensation. I had my doubts.
I have driven the truck several more times over several more days but there has been no repeat of the smoke from the tail pipe.
Coolant Smell. At around the day that I saw the first puff of smoke, I noticed a coolant smell coming from the fresh air vent. It is only present intermittently and only when I am stopped or barely moving. Yesterday, I could not detect a coolant smell on my test drive under multiple scenarios.
Rat Nest. Undoubtedly a coincidence, but I found a rat nest on top my battery before the day of the first smoke. It removed some insulation and piled it on top a battery. At first I thought that the coolant smell might mean the rat had chewed a hose but I could not find a single drop of coolant anywhere in the engine bay. All hose connections appeared dry with no red residue. No drips on the frame rail nor the driveway that I could see.
Coolant Loss and EGR Valve. After driving about 200 miles in the above trips, I noticed yesterday that the coolant was down in the degas bottle about 1" from where I topped it off just a few days prior. I pulled the EGR valve and it looked like it had a black oily paste all over it. It was not a completely dry powder but a paste. I cleaned it with carb cleaner, oiled the orings, and reinstalled it. I then drove 10 miles, parked at a store, then drove 10 miles back. Let it sit for an hour and pulled the EGR valve again. My heart sank. It looks to me that there is red paste smeared on the newly cleaned EGR valve. Please see the picture. There was no "puddle" of coolant in the intake under the EGR valve but there was what looked like a quarter-sized damp spot. I stuck a paper towel in with a tool to tamp it and it made a reddish brown stain on the paper towel (pictures below).
Does this sound like the EGR cooler is broken? I cannot believe it because my temps and deltas have never been that high. The only thing I did was flog the turbo with some WOT runs fully warmed up and with an empty truck. The only odd thing I did was my mechanic friend told me to create more load by applying some brake while I accelerated--I did that once on the freeway at 50mph and it did cause enough load to really spool up the boost. I also heard a sound like a pop/whoosh while I was doing that run.
If it is the EGR cooler, I have not seen anything better regarded than the BPD so would that be the way to go? The BPD H core? I also see that many places say to replace the oil cooler while everything is off. That's a shame because my temps did not appear that bad to me but I understand everything is off so don't be foolish trying to save $500. Ugh.
Thank you for reading this and for any advice you can provide. I'm shocked that this happened even with all of the precautions and babying. I need this expense right now like a hole in my head. Jeff
