1 - 1 of 1 Posts
Says I have a p1267 code on injector 7, I looked at the fuel and it looks clean . Took the fpr off to check it . Looked at harness by Egr cooler nothing looked frayed and did a power balance test and injector 7 is dipping . Anyone have this problem before ? Tia
2011 f350 6.7
767477
Checked fuel and put on a scanner , think it’s a bad injector ? Code is reading high to low short . My question. Would be if I had to do an injector 7 how hard is the job ? Do I have to take valve cover off or can I sneak in with out removing it ?
767478
767479
1 - 1 of 1 Posts
